  New Posts New Posts RSS Feed: Water Pressure Regulator
Topic ClosedWater Pressure Regulator
Tars Tarkas View Drop Down
Direct Link To This Post Topic: Water Pressure Regulator
    Posted: 09 Apr 2014 at 7:48pm
Yeah, aside from keeping freshwater stuff away from sewer stuff, the pressure regulator is to protect plumbing fittings in the pod, especially in case of a pressure surge while you're hooked up.  For the black water flush, just check the pressure on the line before you hook it up.  If you can hold on the hose you are probably safe, and there's no pressure buildup in the black water tank.
TT
FJ Cruiser
Direct Link To This Post Posted: 09 Apr 2014 at 4:22pm
No, do not use the pressure regulator, or your fresh water hose, for anything sewer related. Keep all your fresh water stuff separate from all your holding tank maintenance stuff. Just carry a plain old garden hose for use at the dump station.
ron_whitt View Drop Down
Direct Link To This Post Posted: 09 Apr 2014 at 3:42pm
Yes its probably a good idea to pick a regulator up, as not all camp grounds have the same pressure and you don't want to blow out any connections. As for the black water flush, can't help you there, but I'd assume since your already hooked up with the regulator I'd use it when connecting to the black water flush.
Ron & Shirley
2020 Tacoma
2012 177 rpod
cody91 View Drop Down
Direct Link To This Post Posted: 09 Apr 2014 at 2:01pm
Does anyone use a water pressure regulator when hooking up city water to their Rpod?
If so, do you also use the regulator when connecting the black water flush?
Thanks,
Cody91
