Forum Home Forum Home > R-pod Discussion Forums > Dealer Reviews and Comments
  New Posts New Posts RSS Feed: A.C. Nelson - Omaha
Topic ClosedA.C. Nelson - Omaha
Mountainrev View Drop Down
Direct Link To This Post Topic: A.C. Nelson - Omaha
    Posted: 23 May 2016 at 12:00pm
We bought our 177 from AC Nelson in Sept. of 2014.  I agree about the thorough walk-through.  Got the second year Forest River warranty ($150), but haven't needed any warranty work yet.  With about 3 months to go on the warranty, I'm hoping to not have to find out what dealer would be willing to do warranty work when you didn't buy the camper from them.  We live two hours from Denver and two hours form Grand Junction, the closest R-pod dealers.
2014 177
Direct Link To This Post Posted: 21 May 2016 at 8:09am
Nice set up!
bigjoey38 View Drop Down
Direct Link To This Post Posted: 20 May 2016 at 10:44pm
I got mine from AC Nelson also yesterday..... Have any of you Colorado guys found a place they would do warranty work?  They did a great job with the walk thru... Took time to explain things and answer questions....
2007 Kia Sorento LX 4x4
2016 R Pod 178
Direct Link To This Post Posted: 09 May 2016 at 11:34pm
Hope to visit AC Nelson next week to pick p a 178 if all goes well. I live in Sterling,Co.
ryaninco View Drop Down
Direct Link To This Post Posted: 22 Sep 2014 at 4:56pm
Originally posted by sullyd54
thanks for the info ,i have an auto w/ 3.21 (2012 unlimited sport)  chrysler says 2000lbs max. think I'm going to trade in for a tacoma
That'd be a nice complement to the RPod... I've been thinking about trading up myself into Ram 1500. Not sure if I'm going to yet but the extra power over the Jeep V-6 and 5-speed would be much appreciated. I've been debating on holding out for the 2016 diesel Wrangler... but I'm not anticipating it'll be much improvement for long hauls... you get an 8-speed transmission in the 1500.
Do you do much off-roading...?
2014 RPod 177 (a.k.a The Little King)
2012 Jeep Wrangler
sullyd54 View Drop Down
Direct Link To This Post Posted: 21 Sep 2014 at 8:00am
Direct Link To This Post Posted: 09 Sep 2014 at 2:18pm
Hi sullyd54 & vtwin,
My Jeep is 2012 Sahara w/ 3.73 gears, limited slip diff & automatic trans... I'm actually quite happy with it but it could use some improvement.  It struggles a bit around 65mph and long hills. I generally tow our 177 in 4th gear around 2500-2800 rpms to keep the engine from shifting so much between 4th and 5th.  Like vtwin said, it does shift quite a bit in the higher gears but running it in 4th is no problem.
Also, I have a Reese anti-sway weight-distributing hitch.  I haven't towed it without the hitch but from what I've read from other folks with Jeeps, the weight distribution hitch works much better. Again, I haven't towed it without the hitch but from my personal experience with the hitch, it's rock solid and I'm very happy with it... there's no sway on the trailer even around 65 with trucks passing or side winds.  I would recommend it.
2012 Jeep Wrangler
vtwin View Drop Down
Direct Link To This Post Posted: 09 Sep 2014 at 1:59pm
how does the jeep tow?
Ive got 14 Saharah, 3.21 gears, standard. I pull our 171 in 5th gear 2100rpms 60mph just fine.   Guess it depends how level the ground is where you live, i have to drop to 4th in long hills.. Personally i wouldn't pull one with an Auto unless it had 4.10 gearing knowing how much gear changing it will be doing..
Direct Link To This Post Posted: 09 Sep 2014 at 9:19am
Direct Link To This Post Posted: 04 Sep 2014 at 1:19pm
Originally posted by Mountainrev
Originally posted by ryaninco
Very nice!  Happy to hear that you had a great experience with A.C Nelson as well.
Nice-looking rig you've got there!  How was your drive across Nebraska and eastern Colorado towing the R-pod?  What kind of a hit in gas mileage did you experience?  We've owned popups for over 20 years, so I'm used to towing, but with low-profile popups, you don't get any wind resistance so you can tow at higher speeds with much better gas mileage.  I was a bit shocked to get only 10mpg with my Durango.
Thanks Mountainrev!  The drive back through Nebraska was good actually... Once we got to the eastern co plans... that was a different story... very windy!  We stopped at Sterling Reservoir on the way back for a couple nights to get in our first trip!
I feel you on the gas mileage... I went from about 20.5 on the way out to Omaha to 11.5 towing it back.
2012 Jeep Wrangler
