  New Posts New Posts RSS Feed: Burned out porch light
Topic ClosedBurned out porch light
kymooses View Drop Down
Direct Link To This Post Topic: Burned out porch light
    Posted: 24 Sep 2013 at 7:43am
There is also a little indentation on the bottom of the lens, you can pop a small flat head screwdriver there to help pop it off.
Robwid View Drop Down
Direct Link To This Post Posted: 23 Sep 2013 at 11:35pm
Thanks for the tip!
Rob
2012 HRE 177
2010 Toyota Tacoma
CharlieM View Drop Down
Direct Link To This Post Posted: 23 Sep 2013 at 11:10pm
Push up gently on the bottom center of the amber lens. The lens should pop off. Then push in on the bulb and twist it. While you're at it, replace the bulb with an LED.
Direct Link To This Post Posted: 23 Sep 2013 at 10:38pm
On our 177 we have what we refer to as the "porch light" located on the exterior just to the left of the door.  It burned out this weekend and I couldn't see how to get at the bulb. I didn't have a step ladder so I didn't get a real good look but I didn't see any fasteners. I pried on the lens to see if it'd pop off but I didn't want to break it.  Should I pry a bit harder?
Rob
2012 HRE 177
2010 Toyota Tacoma
