  New Posts New Posts RSS Feed: Plumbing issues
Topic ClosedPlumbing issues
smarsh102 View Drop Down
Direct Link To This Post Topic: Plumbing issues
    Posted: 08 Jul 2013 at 8:18pm
Post above is of wrong size. Needs to be the 1/2" version.
Direct Link To This Post Posted: 08 Jul 2013 at 8:07pm
I had exactly the same issue. It looked like the seal had been pushed out the bottom of the valve.
I simply cut the valve out and replaced it with one of these:
http://www.homedepot.ca/product/sharkbite-ball-valve-3-4-in/977006
Debated doing all of them but decided I would wait until they fail.
Camper Bob View Drop Down
Direct Link To This Post Posted: 08 Jul 2013 at 3:58pm
Ditto on the Oxygenics.  Safe Travels.
Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
Outbound View Drop Down
Direct Link To This Post Posted: 08 Jul 2013 at 2:59pm
Originally posted by Seanl
I am thinking that there might be debris in the faucet behind the vacuum breaker and that the water pressure forces the debris into the vacuum breaker plugging the shower. Has anyone had an issue like this?
I had something similar happen in my r-pod's first year.  There's a restrictor built into the taps where the shower hose screws to it; there were a lot of plastic filings/debris built up behind the restrictor.  I drilled out the restrictor and flushed the line (and didn't bother replacing the restrictor).  I also replaced the showerhead with an Oxygenics Body Spa - its a bit pricey, but WOW what a great shower I've now got in the r-pod.
Seanl View Drop Down
Direct Link To This Post Posted: 08 Jul 2013 at 12:04pm
Okay I had two plumbing issues this weekend. The first is that I sprung a leak in my hot water heater compartment. When I tracked it down the leak was coming from one of the bypass valves on the Hot Water Heater. As an emergency repair I remove the short piece of pex on either side of the  valve and replaced the whole section with a piece of braided water line. When I took a look at the valve body after I got it out it appears that the valve is held in the body only by friction. There must have been a little water int he valve last year after I winterized it and it froze and pushed the valve out of the body.  If I had known how to take the valve apart before I removed it I could have done the repair in place and not have had to replace pex pipe. So here are some pictures so others can learn from my mistakes.
The second problem I had was that the shower would not work. This I did not figure out. The shower comes on for about a 1/2 second and then pressure drops to a trickle. It does it on both the Hot and Cold so the issue has to be in the Faucet. I am thinking that there might be debris in the faucet behind the vacuum breaker and that the water pressure forces the debris into the vacuum breaker plugging the shower. Has anyone had an issue like this?
