  New Posts New Posts RSS Feed: distribution center under table
Topic Closeddistribution center under table
Seanl View Drop Down
Direct Link To This Post Topic: distribution center under table
    Posted: 17 Jun 2013 at 6:35am
Agree just the cooling fan on the converter.
bhamster View Drop Down
Direct Link To This Post Posted: 17 Jun 2013 at 3:08am
Originally posted by bc matell
Its called CONV and is the last switch down on the panel. I have turned it off,noise has stopped. SO whats going on??
It's the 12V converter. It converts 110V AC to 12V DC. If it gets hot then the fan will run to cool it off. Typically it only gets hot when there is a large current draw (battery charging, fridge on DC, lights on, etc...). It might also run if it's poorly ventilated or the weather is just hotter than usual.
Direct Link To This Post Posted: 16 Jun 2013 at 10:37pm
 It could be if you have it hooked up to 110 volts it is charging your battery. David
2014 Ram 1500 Quad cab
bc matell View Drop Down
Direct Link To This Post Posted: 16 Jun 2013 at 10:32pm
no lights were on and are not on now
TV 2012 Toyota Tacoma 6 cyl
Misha the Lab
Loving life and living it!
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 16 Jun 2013 at 9:14pm
There is a cooling fan that runs if you still have incandescent lamps (like we do) and have several of them on. The distribution center is also a power supply and battery charger and needs a fan to stay cool.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 16 Jun 2013 at 8:50pm
Hi ,
Just came back from camping ,parked the pod and now I hear a noise coming from the unit under the table.
Its called CONV and is the last switch down on the panel. I have turned it off,noise has stopped. SO whats going on?? Help and thank you
Misha the Lab
