  New Posts New Posts RSS Feed: Another winterizing question
Topic ClosedAnother winterizing question
Robwid View Drop Down
Direct Link To This Post Topic: Another winterizing question
    Posted: 15 Oct 2012 at 11:25pm
Thanks Kayakkrazy!  I'll check it out this weekend.
Rob
2012 HRE 177
2010 Toyota Tacoma
KayakkrazyUP View Drop Down
Direct Link To This Post Posted: 14 Oct 2012 at 9:45pm
Just remove the panel near the floor directly BENEATH THE SINK and find the little piece of hose going nowhere from a valve on the intake line, assuming the HRE is the same as the other 177s.
2011 R-Pod 177
2012 Jeep Grand Cherokee
Direct Link To This Post Posted: 14 Oct 2012 at 9:26pm
Hello all,
In preparation for winterizing later this fall I want to make sure I understand the procedure.  I have printed out the steps from this website as described by some kind sole.  Everything is clear until I get to the part about locating a 2.5 foot tube and valve on the intake side of the pump for introducing anti-freeze to the system.  I have a 2012 HRE 177.  I removed the access panel in the 'basement' (the rear storage area)  and can see the three valves for isolating the water heater but I couldn't see the above described tube for anti-freeze.  The access panel is really pretty small and I wasn't really able to see the compartment very well.  I felt around a bit but didn't find a loose tube.  Am I going to have to access this area from above by removing the mattress and plywood cover?
As always, thanks in advance.
Rob
2012 HRE 177
2010 Toyota Tacoma
