  New Posts New Posts RSS Feed: Roof a/c filter
Topic ClosedRoof a/c filter
kymooses View Drop Down
Direct Link To This Post Topic: Roof a/c filter
    Posted: 07 May 2012 at 5:32pm
Are you talking about the filters inside the Pod on the AC unit?
Should be two of them with little indentations there at the front like you mentioned that you can pull on.  You won't tear them they are a semi-bendy plastic casing and I would imagine unless they are just completely stuck and you're pulling with a lot of force they'll be okay.
They do seem to stick in their little holes quite easily and are sometimes even more of a pain to put back in after you've washed them off.
We clean ours at the end of every trip.
pugspod View Drop Down
Direct Link To This Post Posted: 07 May 2012 at 4:53pm
I have only owned my pod for a week but I would like to clean the a/c filter(s).  It is a Dometic a/c and I think the filters come out from the front, but not sure since they won't pull out easily.  It sounds scrunchy when I pull, and I don't want to tear them.  Any suggestions?  Thanks, Joy.
Steve & Joy & Harley the pug
