Cooking in the RPod |
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 399 |
![]() ![]() ![]() ![]() Posted: 21 Apr 2025 at 4:17pm |
Unless it was something really easy like warming up soup, we cooked outside most of the time, even in less than perfect weather.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Kawasaki KLR650 |
James07 ![]() Newbie ![]() Joined: 19 Feb 2020 Location: Sacramento Online Status: Offline Posts: 27 |
We just remove the smoke detector when it goes off. Turning on the bathroom fan works too if you can stand the noise. One time I cooked crab inside and it stunk up the place. Never again. I purchased an electric hot plate to cook seafood outside instead.
Pod People ![]() Senior Member ![]() Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1088 |
We cook almost all of our meals in our 179. However, we remove the smoke detector before cooking as it will almost always go off during the process. We also usually open the door immediately next to the cooktop and turn on the fan in the bathroom. Travel often and safe Vann
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3346 |
We remove the battery from the detector when cooking if necessary. Although the majority of our cooking is done on a charcoal grill (outside) a fair amount is still done inside but doesn't generate enough smoke to set detector off such as eggs, onions, veggies, beans, and the like. Keep the window by the stove open a bit (177) and running the FF in the bathroom helps immensely.
LeonMBarnes ![]() Newbie ![]() ![]() Joined: 18 Oct 2024 Location: Wichita Falls Online Status: Offline Posts: 10 |
Help here will be much appreciated.
Do y'all do real cooking in your R-Pod? We don't believe there is any vent to the outside for the propane cook top . Even boiling water sometimes sets off the smoke alarm. Thank you in advance, Leon and Johanne Barnes Adventures in Retirement |
