  New Posts New Posts RSS Feed: Thermostat Replacement?
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Topic: Thermostat Replacement?
    Posted: 01 Dec 2024 at 8:28am
A friend had an extra of the Micro-Air Easy Touch. It took a bit of figuring out the wiring, but it is installed and working great. If yours has the wiring with a plug, it is probably easier than mine was which was direct wired.
I am very happy with it. Whether you can replace a manual thermostat with a digital one though is something I do not know. I think if you can locate a service manual for your AC unit, that would help you determine whether it is possible or not.
adam6 View Drop Down
Post Options Post Options   Quote adam6 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 4:53pm
I don't have an answer, but I'm also looking at others.  The Furion that's on my 203 isn't working properly and I think I might just look for a replacement instead of getting the same one fixed or installed.
Breaktrack View Drop Down
Post Options Post Options   Quote Breaktrack Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 11:55am
I've been looking to possibly replace the thermostat that came in the 192 I purchased used. There are many digital thermostats to choose from for rv's but I have no idea what model numbers are a replacement for the stock one in the trailer.
Has anyone successfully replaced theirs with a digital model and what model was used?
Thanks in advance.
Mac
Six Saturdays and one Sunday per week.
