Introduction - Buggaluggs |
Page 12> |
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6417 |
![]() ![]() ![]() ![]() Posted: 21 Feb 2025 at 5:41pm |
Personally, I would not consider an R-Pod or any other similar travel trailer suitable for such a trip. An Overlanding trailer would be more suited, but would cost significantly more than an R-Pod. One like this would be much more likely to survive the trip to Alaska without major damage.
As I wrote before though, you have been there so you know the road conditions much, much better than I do.
RFX43 ![]() Newbie ![]() ![]() Joined: 10 Feb 2025 Location: Baker, W.V. Online Status: Offline Posts: 3 |
Thank you, great appreciated.
RFX
Thank you. On my last drive up I ran into a couple that lived near me in Montana. They were pulling a large 5th wheel and hit a pothole. To get to the fuel stop/country store, they went through two spare tires. At the store they found out that the closest repair shop was 600 miles away. Thanks again.
RFX
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 392 |
I believe a couple of folks have taken Rpods to Alaska. Be aware that Rpods do not have a robust build. I know I have heard of bent axles and cabinetry falling apart. Do your due diligence and reinforce the axle and brace the cabinets. Good luck.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Kawasaki KLR650 |
That should probably have been posted as a separate topic. The 2017 should have come from the factory lifted or with the arms of the axle re-clocked to make the trailer ride higher than in prior years. That does not mean that adding lifting blocks would not help in your particular situation. Making sure that the RPod is riding level and not with the front higher will help ensure that the drains won't drag. However, the stress of hitting potholes may cause more issues such as the axle losing its camber or bending. Since you have been there, you know the conditions and will need to drive accordingly.
I'm considering lifting my 2017 . have you experienced anything negative after lifting it? I'm looking at another drive up to Alaska this Summer. I have driven up twice with a truck camper. The Alaska Highway system can be a challenge with potholes, lots . I'm concerned about tearing the drains off.
RFX
I think the problem was the campground's power if your RPod works fine at home on a 20A circuit. One thing you can do to help yourself is to get a surge protector/circuit tester. You might have found that the power pole had hot and neutral reversed or some other fault. Look at this listing for some examples:
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3324 |
Had to replace the two rear stabilizer jacks due to the low ground clearance on our 2011 177. Pretty straightforward, didn't take very long to replace. The mod to avoid this, which was done back in 2017, was to purchase a 3.5" lift kit. I got mine from FR ($150 total cost included shipping) but many other reliable companies also have this kit and from what I have seen, at a lower price. Regardless, this was also an easy fix, using 2 floor jacks and basic hand tools, the job was completed in just under an hour. You will need a torque wrench (1/2" or 3/4") to snug the bolts to 120 ft. pounds.
Pod People ![]() Senior Member ![]() Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1088 |
I can't help you on all of the items you mentioned. However, I can tell you that the earlier RPods did not have a wheel on the tongue jack-just a straight post with solid end cap. We bent ours once and replaced it with a simple straight tongue jack from Harbor Freight. they also have jacks with wheels. https://www.harborfreight.com/search?q=tongue%20jack should be a simple replacemnt-some bolt on to the side of the tongue, but the Rpods have a 3 hole type of installation that actually goes through the tongue/a frame. make sure the bolts line up. Travel often and safe Vann |
TheBuggaluggs ![]() Newbie ![]() Joined: 12 Nov 2024 Location: NW Indiana Online Status: Offline Posts: 2 |
I got a slow puncture on the way to Brown County and then we had an electrical problem. Site had 20A and the camper is 30A. We have a converter but it kept shorting out. Even with all on-board breakers open. I figured something had gotten loose on the way but when we got home it worked fine on our house 20A circuit. So maybe the site had an issue. It was a bit chilly, but we had a good time.
We do need some items replaced. I'm hoping I can search through this forum and find recommendations. A new door. Someone broke in to the camper and the door is a little bent and the hinges are bent. The hinges appear rivetted which will make replacement a challenge. I'd be interested if anyone else has replaced a door. Stabilizer jacks. All four appear rusty and two are a little bent. Looks like an easy replacement, but maybe I'm under estimating that! Main wheel jack The wheel is missing from an unexpected scrape down the road. I'm not sure if that is a std item I can buy or a special R-Pod item. I'll search the forum for info, but may post questions if i can't fin answers from my search. Thanks - Buggs
Page 12> |
