Battery Disconnect |
Colt ![]() Senior Member ![]() ![]() Joined: 16 Nov 2019 Online Status: Offline Posts: 383 |
![]() ![]() ![]() ![]() Posted: 26 Feb 2023 at 8:43pm |
I bought this one. It looks sealed. So far, so good. https://www.amazon.com/Blue-Sea-Systems-Battery-Switch/dp/B00445KFZ2/ref=sr_1_3?crid=2WVBGXE2012XW&keywords=marine+battery+disconnect&qid=1677465748&sprefix=marine+battery+disconnect%2Caps%2C129&sr=8-3
John
'16 R-Pod 180 |
gpokluda ![]() Senior Member ![]() ![]() Joined: 11 Nov 2018 Location: NM Online Status: Offline Posts: 399 |
I used the same one as StephenH. Simple and serviceable.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Kawasaki KLR650 |
I'd suggest getting an old school battery top post knife switch. Like anything else exposed outside it can get corrosion but since the switch part is open its easy to inspect and maintain. About $13 on Amazon.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6428 |
You could check Amazon to see if you can find one. Look for a marine one. The problem is that they are outside and exposed to all kinds of conditions. I purchased one like this:
I had it outside for a while, but when I installed the Lithium Iron Phosphate battery, I moved it inside to be close to the battery.
My battery disconnect switch has become so stiff I cannot move it by hand. I want to replace it with a quality switch. Any suggestions?
My nearest RV dealer was out of stock. |
John
'16 R-Pod 180 |
