Bi-Metal switch 8501 refrigerator inop |
Page 12> |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3363 |
![]() ![]() ![]() ![]() Posted: 24 Sep 2022 at 8:10am |
I have heard that comment from many podders over the years and this is my fix. Dometic installs the bi-metal switch too far away from the chimney exhaust, usually between 6th or 7th and 8th fin to the left where there are a couple inches between the first stack and second stack of cooling fins. Remove the bi-metal switch and move it to the right, to within 2" of the chimney stack. If the bi-metal switch is properly functioning and the fridge is on, I can nearly guarantee that your muffin fans will turn on within a minute. Even on our last trip I this past month we were at the Black Canyon of the Gunnison NP in Colorado and two other podders were discussing this problem they were having with cooling. In both cases I moved the switch and in both cases the muffin fans kicked on within 30 seconds. Both owners had the same response of "I never heard those fans come on before." By doing this simple step the fans will not only turn on but run longer, resulting in much colder interior fridge temps.
Pod People ![]() Senior Member ![]() Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1088 |
The fans on one of my friends R Pod never worked either. He changed the thermoswitch and now they work. So I would assume that your thermos switch is bad similar to what J A pod just went through. You can probably check that switch with a hairdryer or heat gun to see if it’s working. Use your infrared thermometer to see what temperature it turns on and off.
Hope that helps Travel safe and often Vann
hogone ![]() Senior Member ![]() ![]() Joined: 09 Apr 2013 Location: High Ridge, MO Online Status: Offline Posts: 1062 |
my fans have never run
Jon & Pam
2013 RP177 2023 F150 2017 HD Streetglide CHEESEHEAD |
JA-Pod ![]() Newbie ![]() ![]() Joined: 28 May 2019 Location: Raleigh NC Online Status: Offline Posts: 35 |
Agree that the original fan draws so little power and i do not boondock (yet) so no real concern. I am not sure if the oem thermo ever worked as i do not recall ever hearing the fan working. I had assumed that with one of the wires from the thermo going to the control box mounted on the back of the fridge this would signal to the thermostat to "wake up" to start monitoring for heat. Something to ponder and ask other podders when out there in the world. All is well.
thanks again for your advice, Vann cheers! John
John & Allison
R-Pod 179 (2017) Nissan Frontier SL V6 4.0 (2019) |
That looks like a nice job overall. I agree that it is surprising that the fans come on even with the refrig powered off-I'm pretty sure that I have never heard our fans come on if the refrig was off. but, there is probably very little parasitic power drain from the fans so it should not be a big issue. I wired 2 additional fans to the original wiring controlled by the thermoswitch and they(both original and added fans) all come on/off at the same time. since you added a separate manual switch for the additional fans, they are not controlled by the thermoswitch. so there is no connection between the 2 new, manually operated fans and the original fan operated by the thermoswitch. Perhaps the original fan wiring has an interface that only allows the fan to run when there is power to the fridge.????? but there is always power available (even if not used) to the refrig whether on shore power or battery. so that doesn't make total sense either. It would have to be connected with the refrig motherboard in order to "know" that the refrig was actually in operation and for the fans to turn on when temp is reached. the fact that the original fan will come on without the refrig being used is a mystery to me. do you recall it working that way before the installation of the new thermoswitch? In our first pod(173) I added 2 fans and direct wired them to a switch just as you did. They were totally manual and not connected to a thermo switch, so were totally independent from the original fan controlled by the thermoswitch. so, your install is approiate. However, if you want them to be controlled rather than manual, you could wire the new fans in series with the original fan/wiring. either way, the idea is to keep the back recess as cool as possible. Good job Travel safe and often Vann
The last pic will show the thermal disc purchased from Amazon 100 degree closed opens at 85 degree https://www.amazon.com/dp/B019VSPFGA?psc=1&ref=ppx_yo2ov_dt_b_product_details attached using the original wires, had to change the spade connector size. Now the fan will turn on at 100 degrees. One spade connx is to power and the other to the controller. Interesting the fan will run even when the refrigerator is powered off, not sure if this is standard since I do not know if the fan has ever worked. I was hoping the controller will signal when the fridge is on to then look for the thermal switch to do its work to turn on the fan. Anyone know if this normal? Added two muffin fans https://www.amazon.com/dp/B08VHT6RVP?psc=1&ref=ppx_yo2ov_dt_b_product_details attached them to the connect block as shown then added a manual rocker switch installed in the pod to turn on the fans (see the wiring diagram for the switch). ![]() ![]() ![]() ![]() |
John & Allison
Appreciate your help with this Vann, i ordered the switch and additional fans, will install and post the results for others who may be running into the same issue with the OEM switch.
John & Allison
I agree that the "stock" switch info seems to indicate that the operating and differential temps seem very low. Turning the fans "ON" at 70 degrees is really outside ambient temp without any internal heat being added from the refrigerator itself. Also the difference of only 10 degrees seems very low and would indicate that the fan would stay "ON" most of the time when powered by propane. I know that my 179 stock switch does not make the fans stay on all the time--it definitely cycles on/off. I have never actually measured the on/off temps. I am seldom using the refrigerator on electric, most of the time boondocking on propane. I assume that propane will create higher operating temps than electric, but don't know that as a fact. I do know that my traveling buddy used that Amazon switch and has been happy with the operation for at least a year. we travel together frequently and his refrig and cooling fans works well. travel safe and often Vann |
thanks Vann, i noticed this on Amazon,
Found after doing some research and probably way too much info for a simple device. For my 2017 179 year Dometic 8501 refrigerator the Thermostat thermal bi-metal switch numbers are 36TXE32-14582 F70-10C A1541. The brand of the device (although not identified on the switch) is Therm-O-Disc by Emerson. The numbers are as follows: https://climate.emerson.com/documents/bimetal-36t-section-en-us-5469058.pdf so this is a Automatic reset switch with a switchcase design, eyelet construction, stud mount with the contacts closing on temp rise. I believe the F70-10C indicates that the contacts close at 70 degrees (then turns on the fan) and will reopen when the temp falls to 60 degrees (-10C). This seems very low closing the contacts and return to open at 60 degrees which if working correctly would run the fan most of the time. I like the idea of the switch you mentioned, it will close at 100 and open at 85 although I am not sure what the "normal" temp range of the pipes near the cooling fins would normally run at. Any idea? |
John & Allison
There are several switches listed on amazon. My buddy used this one on his 179 refrig. https://www.amazon.com/gp/product/B019VSPFGA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 there are different temps (on/off) available. travel safe and often' Vann |
Page 12> |
