2022 Rpod 190 LP Fridge F code (resolved) |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3340 |
![]() ![]() ![]() ![]() Posted: 06 Aug 2022 at 6:36pm |
Good to remember this when it comes time to changing out the propane tank. Light the stove first, it will take 12-15 seconds to clear air out of the lines. After that you can light the fridge on propane, usually will take 5 or 6 attempts before it will light as the air will need to be purged out of that line as well.
npalumbo89 ![]() Groupie ![]() Joined: 31 Jul 2022 Online Status: Offline Posts: 68 |
I ended up finding the manual after digging through all of my paperwork and it suggested that for the fault code F to open all of the propane valves to verify propane is flowing and then shut the unit off and power cycle and let the unit try to ignite after being powered on. After doing this three times the pilot light finally lit and the unit cleared the fault code.
Nicholas Palumbo
Nicolas I see you posted resolved. Let us know how or what you did to resolve the issue. Thanks
Thank you for the tip. I’ll give it a try!
Nicholas Palumbo
Rpod-Couple ![]() Groupie ![]() Joined: 21 Jun 2021 Online Status: Offline Posts: 45 |
Couple things to try: make sure the valve at the propane tank is open (turned fully to the left/anti-clockwise) Second, light the burner on your stove top. The burner makes sure gas is flowing and fills the line. Once your stove top lights, retry the fridge propane button. If your stovetop won’t light you may have a problem with the gas valve, hoses, or no propane in the tank.
Steve & Elaine
2021 R-pod 2023 VW Atlas Cross Sport |
Good morning and I hope someone can help. I’m in a new 2022 Rpod 190 and the LP mode on the norcold fridge does not seem to work. I see an F code on the screen. I flipped the breaker off and on and can here it trying to ignite but nothing seems to happen and the F pops on the display. Is there anything I can easily do to fix this? Im setup on a non electric site unfortunately.
Nicholas Palumbo
