  New Posts New Posts RSS Feed: Is it safe to mount things to walls?
npalumbo89 View Drop Down
Post Options Post Options   Quote npalumbo89 Quote  Post ReplyReply Direct Link To This Post Topic: Is it safe to mount things to walls?
    Posted: 05 Aug 2022 at 10:47am
Okay great. Simple enough.
Nicholas Palumbo
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 11:36pm
Yes, they are simply a block of wood through which I drilled an appropriate size hole and then attached to the wall with screws.
Post Options Post Options   Quote npalumbo89 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 10:58pm
Thanks for the visual. Assuming you custom made those? I’ve got to take measurements and get a feel for it this weekend when I’m camping for the first time in it.
Nicholas Palumbo
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 8:49pm
Okay, pictures are in order so here is one. I would have done the other side, but got an error message about exceeding my picture allotment. Since I don't want my old posts to have broken picture links, I am just uploading this one. There is an equivalent on the other side, notched to allow it to sit flat on the wardrobe cabinet and not interfere with the radio/DVD player.
Post Options Post Options   Quote npalumbo89 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 5:02pm
Okay good to know. I may take a similar approach.
Nicholas Palumbo
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 4:56pm
Since mine is not under that much pressure because I put blocks of wood to hold the two ends, I leave mine up all the time.
Post Options Post Options   Quote npalumbo89 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 3:56pm
Thank you for the tips. Didn’t consider taking down the tension rod while traveling but that is definitely something I’ll look to avoid.
Nicholas Palumbo
CAPTKIDD View Drop Down
Post Options Post Options   Quote CAPTKIDD Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 3:12pm
I use Alien Tape to attach things to the walls it will even hold heavy things.  t is removeable and wont mar the walls in any way
CAPTKIDD
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 2:15pm
We have had good luck with Command hooks as well for lighter things. We do have a few items mounted using screws. We use the 1" particle board screws from Lowes with a dab of wood glue on the threads. Don't pre-drill and hand screw them only and you should be good to go.
Ditto on the spring loaded shower curtain rods for drying towels and clothes. Not sure it matters, but we take them down while traveling. Hate to stop and see big, gaping holes in the wall from the rods.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Kawasaki KLR650
Post Options Post Options   Quote npalumbo89 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2022 at 9:54pm
That’s a great idea. Thank you! I also have a big pick up the command hooks too. I came across some adhesive metal strips that I could attach magnets to things and then to that.
Nicholas Palumbo
