  New Posts New Posts RSS Feed: Screen Door Sentry
Screen Door Sentry - Event Date: 10 Jun 2022
poston View Drop Down
Post Options Post Options   Quote poston Quote  Post ReplyReply Direct Link To This Post Calendar Event: Screen Door Sentry
    Posted: 12 Jun 2022 at 11:51am
If I may offer some assistance:
Jim
Virginia City, Nevada
2016 R-pod 180
2015 Nissan Xterra Pro-4X
Dengle View Drop Down
Post Options Post Options   Quote Dengle Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2022 at 11:37am
Yes. Photos would not upload on Rpod Owners Forum; however, did upload on the Forest River Forums (RV Life) under "Fifth Wheel/Travel Trailer/Ultra Light." See sub-forum "Rpods." Or, if wished provide email address and I will forward. Dengle
2020 Jeep Grand Cherokee,V6
w/tow package
_WW_ View Drop Down
Post Options Post Options   Quote _WW_ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2022 at 10:39am
Originally posted by Dengle
The night temperature allowed sleep with an open door; however, my wife wished confidence the screen was “somewhat” secure.   A tell-tale rattle would surely “wake us up.” Avoiding metal bolts/latches, consider this: Obtain an 8” length, small diameter dowel, toilet float rod or aluminum rod. This, to be inserted through the end of the screen door cross bar, the “grab” handle (if installed). The plastic end bracket requires a centered hole, the diameter of the dowel or rod. Since the grab bar is positioned inward from the screen, the rod does require a short wooden block or dowel of proper size, to snug around the door frame (this resembling a handle). Drill through the block or dowel (end to end) with the rod inset, permanently glued or otherwise fastened. When locked, screen door movement is minimized. Only those familiar know the screen door unlocks easily from outside, just hand unfastening, reaching through the plastic slider panel. Installation photos depict Forest River Rpod 179. For photos, see Forest River Forum, under heading "Rpods."
Do you have photos?
2014 RAM 1500
2016 R Pod 179
Post Options Post Options   Quote Dengle Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2022 at 1:51pm
w/tow package
