  New Posts New Posts RSS Feed: ZAMP SOLAR 6 watt
ZAMP SOLAR 6 watt
Pod People View Drop Down
Post Options Post Options   Quote Pod People Quote  Post ReplyReply Direct Link To This Post Topic: ZAMP SOLAR 6 watt
    Posted: 27 Apr 2022 at 1:30pm
the meter will read a negative number(-12.3 etc)
safe travels
Vann
Vann & Laura 2015 RPod 179
Texasvet1991 View Drop Down
Post Options Post Options   Quote Texasvet1991 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2022 at 12:09pm
How can you tell if its REVERSE POLARITY on my RP178 using the multimeter...
James Adkerson
Post Options Post Options   Quote Texasvet1991 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2022 at 12:07pm
Thank you will do... appreciate your help..
James Adkerson
GlueGuy View Drop Down
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2022 at 11:29am
The Zamp connector is wired reverse polarity on some early Rpod installations. You really need to get yourself a meter to check voltages.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2022 at 11:29am
Please look at possible solution under your other post.
Post Options Post Options   Quote Texasvet1991 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2022 at 11:26am
When I plug my Zamp solar 60 watt into the Prewired Zamp port on my RPOD 178 I get a code 601..
I looked on Youtube and he said the code means battery not connected...
I put the solar panel out in direct sunlight for 3 hours and get the same code 601...
If the battery is dead will that be the cause????Ouch
 Marine Battery 2 years old..
James Adkerson
