  New Posts New Posts RSS Feed: Interesting battery analysis
Old Man Running View Drop Down
Post Options Post Options   Quote Old Man Running Quote  Post ReplyReply Direct Link To This Post Topic: Interesting battery analysis
    Posted: 11 Dec 2021 at 12:19am
Thanks Stephen for keeping me straight on connecting the solar panel directly to the battery.  I misspoke on this issue.   I do know that there needs to be an interfacing charge controller between the solar panel and the battery.  When I said that I intended to connect the solar panel directly to the battery, I meant that I did not intend to use the RV's prewire connection.  Thanks for the link to the solar panel article and thanks to Offgrid for his detail explanation.
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 10:00pm
Re positive vs. negative grounding, that refers to which polarity in the system wiring is connected to the trailer and tow vehicle chassis. That is the negative buss in all but some now antique cars. So yes you need a solar charge controller that can be negative grounded, meaning the negative conductors in the circuit are connected together and never opened, so that the charge controllers battery voltage regulation action is done on the positive side of the circuit.
There is sometimes confusion about positive vs negative grounding effects on the solar modules themselves. Some solar modules operating at high voltages (as in a big residential or commercial grid tie system) need to be positive grounded to protect them from potential induced degradatiin (PID) which occurs via leakage of ions through the glass and plastic encapsulation of the solar cells. While PID can be a big deal with some solar module types operating at high voltages under some conditions it's really a non issue for our little 12V power systems.
Re connecting a solar module directly to a battery +1 on not doing that. First and foremost, there has to be an appropriate fuse or circuit breaker protecting the wiring from the battery to the solar module. That fuse should be placed in the positive conductor (to maintaing negative chassis grounding as discussed above) as close as possible to the battery because the battery is effectively an unlimited source of current if you short it out. The solar module can only produce as much current as it has sunlight shining on it so it doesn't need a fuse (unless you have more than 2 parallel connected solar modules which we don't usually need to get into discussing here).
The other reason not to direct connect is that you can overcharge your battery which especially in the case of Li batteries can cause a really nasty thermal runaway effect resulting in a fire.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 4:28pm
One  correction: You do NOT want to connect the solar panel directly to the battery. It needs to go through a charge controller. The WFCO information is okay as concerning when you are connected to shore power. However, the WFCO converter does not act as a charge controller for a solar panel.
There are two types of charge controllers you can use. PWM and MPPT. See this article for an explanation of what those letters mean:  https://www.generationsolar.com/charge-controllers/solar-charge-controller-types-shunt-pwm-mppt/
Post Options Post Options   Quote Old Man Running Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 3:42pm
After contacting the WFCO tech services, I learned that to install a Lithium ion battery I must replace the existing converter, which consists of the 120 volt AC circuit breakers and the 12 volt DC fuses.  He further indicated that the term Control Charger and Converter were really the same thing.  He indicated that I must replace the existing model WF-8735P with model WF-8735-PB-LIS.  The newer model provides the option to switch from Lead-Acid to Lithium to AGM.  The only problem is that the sources of supply are out of stock, so my project may be put on hold until the parts become available.
Also, my RV is pre-wired for solar, but from what I understand you will probably want to connect the solar panel directly to the battery.  I do not intend to make the solar panel(s) a permanent installation, but prefer a mobile arrangement.
I hope that the information I have provided above will be of use to other Forum members.
Thanks for your help, it was most appreciated.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 3:06pm
Is your RPod equipped with solar or just solar ready? If it is the second one, then the wiring is in place, but things like solar panels and charge controllers are not. Since I have no idea about 2021 models, I really can't help you much.
Post Options Post Options   Quote Old Man Running Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 1:24pm
Thanks Stephen for your timely reply.  I am wondering where the charge controller is located.  I have located the Power Converter with Panel, which basically contains the circuit breakers for the 120 volt AC power and fuses for the 12 volt DC power.  I assume that the charge controller is a smaller box, but not sure where it could be installed.  Any thoughts?
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 9:49am
Okay. A lot depends on what model converter is installed. Check your manual to see whether there is a switch to enable you to set it for proper charging of the LiFePO4 battery. Since it is 2021, it is more likely than it was with our 2016. As for solar panels, the charge controller is the key there. The panel just produces electricity. The charge controller applies it. I chose a Renogy system that was negative ground to match the negative ground of the RPod. I saw that some panels were available with positive ground. Offgrid would need to answer but as for me, I avoided the positive ground models.
Post Options Post Options   Quote Old Man Running Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2021 at 11:15pm
I am considering replacing my current Lead Acid 12V battery to the LiFePO4 and have two basic questions.  I currently have a 2021 RPod-196 and was wondering if I need to replace the Charge Controller currently installed in the RPod.  Second question is whether the LiFePO4 can be charged with a solar panel, and if yes, do I need a solar panel with any special requirements?
Post Options Post Options   Quote offgrid Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2021 at 7:41pm
Good idea, your electrical system is likely to outlive the trailer itself.
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2021 at 1:21pm
I tried to make my conversion so that if and when we change trailers, I can revert the RPod to lead-acid and move the LiFePO4 equipment to a new trailer. I still have the WF-8955MBA and the rest can be removed and the connections switched to support the battery on the tongue again.
