  New Posts New Posts RSS Feed: Cabinet doors
Topic ClosedCabinet doors
Olddawgsrule View Drop Down
Direct Link To This Post Topic: Cabinet doors
    Posted: 25 Nov 2020 at 2:19pm
Originally posted by Grenna
Good idea but I would rather not mess with keys.
Get that, but... they just don't fail! Doors stay shut. Lock before you leave, unlock once there. Never found it to be a PITA.
Each to our own..
Now storage behind those doors is something else!
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
SC for Huskers View Drop Down
Direct Link To This Post Posted: 25 Nov 2020 at 11:25am
 I use what StephenH uses and that is the Cupboard Adjustable Spring Rods. Never had the doors open since.
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
Direct Link To This Post Posted: 25 Nov 2020 at 11:16am
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
Direct Link To This Post Posted: 25 Nov 2020 at 10:09am
We have 8 tambour doors, 3 awning doors, and 1 by pass door, and 2 hinged doors ( self closing hinges ) on the cabinets
EchoGale View Drop Down
Direct Link To This Post Posted: 25 Nov 2020 at 9:55am
I have some small throw pillows that normally live on my "couch" but when I travel I stuff them in the cabinets. Works great.
Julie
Direct Link To This Post Posted: 25 Nov 2020 at 9:47am
Use the spring loaded bars in front of the items in your cabinet and refrigerator. That will help. Another thing that helps is to find some bins that can hold items. Those bins will not move so easily. We don't have cabinet doors or drawers opening on us. We have had knives in a block on the rear kitchen countertop bounce out of the block. I now put a small bungee cord around those to make sure they stay in place.
Edit:  Adding links.
Direct Link To This Post Posted: 25 Nov 2020 at 8:50am
Trailers going down the road are subject to the equivalent of a continuous earthquake. The latches are intended to keep the doors closed but not to stay closed when there is heavy stuff pressing on them from the inside. If you have heavy items moving around or items that press against the doors while you are driving they will inevitably be pushed open. You might try repacking to keep things from pressing on the doors.You can use plastic tubs or bins to contain heavy items within the cabinets.
Grenna View Drop Down
Direct Link To This Post Posted: 25 Nov 2020 at 8:29am
Yes that’s what’s in there now and they seem to be aligned ok. Not perfect but when I pull on the doors they seem secure. Until I start driving.
Grenna
Direct Link To This Post Posted: 25 Nov 2020 at 8:26am
Grenna
mjlrpod View Drop Down
Direct Link To This Post Posted: 25 Nov 2020 at 8:00am
Amazon sells these, I can't find the link but this is a description.
Alise 12 Pack Cabinet Closet Doors Roller Catch Latch,CA1000-12P Oil-Rubbed Bronze Copper Finished
You should have this type of catch in your 193 now, but if they alinged correctly they dont work.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
