  New Posts New Posts RSS Feed: Fridge Question
Topic ClosedFridge Question
john in idaho View Drop Down
Direct Link To This Post Topic: Fridge Question
    Posted: 22 Sep 2020 at 12:48pm
addendum to what I wrote above.........
It is like when your grandkids bring a toy to you that isn't working right.  When all else fails, change the batteries -- you'll look like a champ !!!!
TimK182G View Drop Down
Direct Link To This Post Posted: 22 Sep 2020 at 12:33pm
Like everyone said above definitely install a battery to at least have the braking system work if ever needed.  I went cheap and bought a new deep cycle lead acid battery from Auto Zone for less than $100 since we exclusively camp in campgrounds.  You don't have to pay the core charge if you trade in a similar dead battery (car, RV or boat works, as long as it is similar).  I also bought a disconnect switch off of Amazon for $30 that attaches to the negative terminal and eliminates battery drain when it is flipped up.  Pretty nice to have.
2018 R-Pod 182G
2014 GMC Sierra 1500
lostagain View Drop Down
Direct Link To This Post Posted: 22 Sep 2020 at 11:58am
The refrigerator needs a 12 supply to run the control circuit board and lights.
More importantly, the brakes also need a battery if the emergency break away is activated.  No power, no emergency brakes.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Direct Link To This Post Posted: 22 Sep 2020 at 10:29am
I think you need a  battery to make things work right with a stable voltage..
podwerkz View Drop Down
Direct Link To This Post Posted: 21 Sep 2020 at 10:10pm
During this test was your trailer plugged in to your tow vehicle?
Sounds to me like there is 12v being supplied by the tow vehicle, enough to to run some circuits at minimal level, AND the fridge is NOT being supplied by shore power properly, possibly a circuit breaker has tripped or maybe its unplugged behind the vent.
Direct Link To This Post Posted: 21 Sep 2020 at 8:05pm
If the trailer is plugged into shore power then it will supply voltage to the 12v circuits, including the fridge. The question is, would the voltage be stable enough to keep the fridge controls operating correctly. I don’t know, never tried.
I suggest you install a battery and see if that fixes your problem. You need a battery anyway to operate your breakaway trailer brake circuit, even if you stay on shore power all the time.
duldcimerbob View Drop Down
Direct Link To This Post Posted: 21 Sep 2020 at 7:00pm
Ok, I get it the led array control board . Thanks
Direct Link To This Post Posted: 21 Sep 2020 at 6:16pm
I have no idea what the control board is please explain. Thanks
mcarter View Drop Down
Direct Link To This Post Posted: 21 Sep 2020 at 6:11pm
You have no battery? What is running your 12V control board? I think you may want to furnish a battery.
Direct Link To This Post Posted: 21 Sep 2020 at 6:04pm
I am leaving tomorrow for a trip so I plugged in shore power and turned on fridge to cool down overnight. I have no battery and don't use the gas. The LED shows the fridge on battery . When I change the mode to shore power I get a red warning light. I get the same light on the gas setting. Strange thing is I can hear the fridge operating with the battery symbol lit. Could use some help please. Thanks
