  New Posts New Posts RSS Feed: Water pressure
Topic ClosedWater pressure
Direct Link To This Post Topic: Water pressure
    Posted: 09 Jul 2020 at 5:24am
Originally posted by podwerkz
Originally posted by offgrid
Maybe something got clogged in between (1) and (2).
This happens to me every now and then also.
LOL
No way I'm going there......Disapprove
podwerkz View Drop Down
Direct Link To This Post Posted: 08 Jul 2020 at 2:06pm
LOL
Direct Link To This Post Posted: 08 Jul 2020 at 6:56am
So to recap, and maybe I have this wrong:
1) Good water pressure out of all faucets on city water. That tells us the shower is OK.
2) Good water pressure out of all but the shower on the pump. That tells us the pump is OK.
3) The valve on the shower head did not get closed accidentally between tests (1) and (2).
The only other thing I can think of is to go back on city water now and try the shower again. Maybe something got clogged in between (1) and (2).
Direct Link To This Post Posted: 07 Jul 2020 at 7:36pm
On ours, between the pressure restrictor and the water filter on the city water connection, we get better water pressure in the shower with the water pump.
mcarter View Drop Down
Direct Link To This Post Posted: 07 Jul 2020 at 6:43pm
I think it would always have a pressure issue. Not be good in city water and bad on the water pump. The water pump itself could be the issue.
RoverPod View Drop Down
Direct Link To This Post Posted: 07 Jul 2020 at 6:37pm
Is it possible that the screen/filter in the pump itself is clogged?
Cadeeli View Drop Down
Direct Link To This Post Posted: 07 Jul 2020 at 3:06pm
Correct.
Pod_Geek View Drop Down
Direct Link To This Post Posted: 06 Jul 2020 at 3:20pm
My read is that when hooked up to city water the shower pressure is fine, but not so much when using the FW tank/pump.  Cadeeli, did I get that right?
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
GlueGuy View Drop Down
Direct Link To This Post Posted: 06 Jul 2020 at 2:49pm
Sounds like the screen at the shower may be clogged. This is quite common for the faucet at the kitchen sink; maybe not quite as often for the shower.
Direct Link To This Post Posted: 06 Jul 2020 at 1:51pm
it might be higher pressure when connected to city water but it should be fine on the pump too. You don't have the little shutoff valve on the shower head closed by any chance do you?
