  New Posts New Posts RSS Feed: Refrigerator Condensation Tube Re-Route
Topic ClosedRefrigerator Condensation Tube Re-Route
Wirat View Drop Down
Direct Link To This Post Topic: Refrigerator Condensation Tube Re-Route
    Posted: 19 Feb 2020 at 6:31pm
BTW we are in a different campground today and I was having a conversation with the guy next to me about the fridge condensation drain tube thing. He bought his trailer new two years ago and after we talked, he called me over because he had apparently never taken the outside vent cover off,  so he wanted to see what I was talking about.
He had a condensation drain cup there (Norcold, but similar design) and a condensation drain hose, but the hose was just hanging there, leaking, hanging outside the cup, and the hose also had a plastic shunt plug in the end of it!!!
It was as if the builders didn't finish the installation by taking the plug out and placing the hose in the cup. There was condensation water dripping out the end of the hose even with the plug in it, and condensation drain water had been leaking on to the wood area there in the vent compartment. Cry
We took the shunt plug out and placed the hose end in the cup. It didn't look like there was any rot from what we could see, but the guy was pretty surprised and said he had no idea it worked like that. I would have not known either if someone else hadn't pointed that out to me and with the help of contributions here. Thumbs Up
Direct Link To This Post Posted: 19 Feb 2020 at 6:06pm
Yeah that link works and great job! Looks heavy duty. Thanks for sharing!!!
JR View Drop Down
Direct Link To This Post Posted: 19 Feb 2020 at 12:50pm
The link works for me and the idea for the hanger looks really good and should hold up
Jay
179/2019
mjlrpod View Drop Down
Direct Link To This Post Posted: 19 Feb 2020 at 9:24am
Originally posted by Wirat
@mjlrop the URL you posted to the photo isn't working for me, can you check if the link is valid please?
See if this link works. I know i've posted in the past, so hopefully this works.
https://photos.app.goo.gl/2Rz4gwZnRrxsdHas5
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 18 Feb 2020 at 2:47pm
Thanks for the idea. I saw someone who had that problem too and they used metal banding strap. I got down there and can see how cheesy the hanger is and how fast it can probably fatigue and break.
@mjlrop the URL you posted to the photo isn't working for me, can you check if the link is valid please? Maybe the picture isn't marked as shared in your Google account or something? I would like to see what you got...
Direct Link To This Post Posted: 18 Feb 2020 at 7:43am
+1 on strengthening the black tank tube hanger. I had the factory version fail. Then a second one was added by the factory. Both of them failed. Both times, the result was the end of the tube dragging on the pavement, the second time with the valve coming open on a pretty full tank. I am sorry for the people who were behind us. There won't be a third time since I then added my own hanger that is much stronger and is not tied directly to the pipe so the road motion flexing it won't fatigue and break the metal. Plus, there are no nuts holding the hanger to the pipe which could vibrate loose. Pictures are in my mods (see link in signature).
Direct Link To This Post Posted: 18 Feb 2020 at 7:27am
I'm trying to get ahead of problem issues now while we first have the R-Pod so this is well appreciated.
Speaking of getting ahead of problem issues, I'd be more concerned about reinforcing the hanger strap for the black tank tube.  THAT will make a much bigger mess than the few drops of water from the fridge.
I have a photo of the hanger I made. A bit over engineered, but it was the best available parts I could get.
Sorry, see if this one works.
2017.5 Rp-172
2020 R-pod 195
I'll be rpodding
Direct Link To This Post Posted: 18 Feb 2020 at 4:50am
Wow thanks for all the feedback! Thumbs Up I did not notice there was a coolant line in there. I'm trying to get ahead of problem issues now while we first have the R-Pod so this is well appreciated.
Direct Link To This Post Posted: 17 Feb 2020 at 11:37pm
I extended the tubing through the floor, now it drains under the trailer
Direct Link To This Post Posted: 17 Feb 2020 at 8:18pm
What condensation goes down into the cup will evaporate from the heat of the coolant running through the pipe around which it is wrapped. The only bad part is if it cracks. Mine did, but I patched it and still have the hose running into it. If it cracks again, I will likely extend the hose out the vent also.
