  New Posts New Posts RSS Feed: Freshwater tank
Topic ClosedFreshwater tank - Event Date: 02 Apr 2019
Shane View Drop Down
Direct Link To This Post Calendar Event: Freshwater tank
    Posted: 01 May 2019 at 1:21am
I agree, its most likely the check valve. My 180 did the same exact thing. Camping world Chicago where I bought it replaced the water pump under warranty.
ENGINE 55,TRUCK 44,BATALLION 12
Direct Link To This Post Posted: 15 Apr 2019 at 9:13am
Originally posted by TheBum
Originally posted by furpod
You can replace just the valve, or do the pump head, both available on Amazon for a few dollars, takes a couple minutes. Just google your pump model number...
That "couple of minutes" is after getting to the pump, which is typically under the bed. Depending on your mattress choice and any provisions you've made to make access easier, that could easily double the time.
"typically" the pump isn't under the bed.. but in the most popular model, the 179, it is. But yes, there may be time and effort involved in getting to the pump.
LEGZ View Drop Down
Direct Link To This Post Posted: 15 Apr 2019 at 8:22am
Took R-POD out for test run last weekend ran water pump for 4 days. Got home hooked up to city water, freshwater tank getting better not filling up but water still slowly getting into tank. So I will keep working check valve. Thanks
TheBum View Drop Down
Direct Link To This Post Posted: 04 Apr 2019 at 10:45am
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
mcarter View Drop Down
Direct Link To This Post Posted: 03 Apr 2019 at 7:01pm
I went thru a year of this issue. Cycling is right answer, but it didn't work for me. I never could figure out why check valve was not working. Finally changed water pump and problem solved.
Direct Link To This Post Posted: 03 Apr 2019 at 6:59pm
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 03 Apr 2019 at 6:34pm
Originally posted by LEGZ
When i find water pump does the whole pump need to be replaced if only check valve is bad, or can check valve just get replaced..
I think you can replace just the check valve, I'm not sure, but there's a good chance it's just stuck.  You may have already fixed it by filling the tank and using the pump.  Try hooking up to city water again and see if the tank still overflows.  If it does, the tank is full, so just turn the pump on (and city water off) and cycle the water off and on a few times and try again.
TT
FJ Cruiser
LEGZ View Drop Down
Direct Link To This Post Posted: 03 Apr 2019 at 5:12pm
Billy Bob View Drop Down
Direct Link To This Post Posted: 03 Apr 2019 at 9:27am
+1 to glue guy....I had the same thing only a very slow leak from the pump into the fresh water tank.  FR replaced it under warranty though I was told the pump itself is very inexpensive
2019 RPOD 190
2017 Chev Colorado 4 X 4
GlueGuy View Drop Down
Direct Link To This Post Posted: 02 Apr 2019 at 9:06pm
It's most likely the check valve in the water pump that is stuck or clogged. This link is a discussion of the issue.
