Jenga Jack
Topic: Leaky faucet connector Posted: 20 Mar 2019 at 6:19pm |
Thank you Podders for your input. Appreciate all the feedback. Happy trails!
2014 R-Pod 178 aka the "Kobra Pod"
following a 2015 4Runner wherever it may wander
Happy Tripping
Posted: 20 Mar 2019 at 6:03pm |
Originally posted by furpod
That white connector is part of the faucet assembly itself. I doubt you will find any service parts. If that's where the leak is.. the easiest answer is a new faucet fixture. A better one. |
I agree. The standard r-pod faucet is one step down from #*@*!! worthless junk, it could be leaking anywhere inside. Switching out with a quality faucet is simple, I did it successfully myself and am definitely not a 'handy man'.
Jenga Jack
Posted: 20 Mar 2019 at 5:52pm |
I can't get into the space with enough headroom/visual look-see, but I think the leak is seeping out of the top "screw device" that threads into the connector piece. Striped threads? Cracked "screw device"?
Posted: 20 Mar 2019 at 4:35pm |
Agreed. Jenga Jack, can you clarify exactly where you think the leak is?
Posted: 20 Mar 2019 at 4:31pm |
I swapped out for this one by Peerless
Posted: 20 Mar 2019 at 3:54pm |
OK, I see the photo now. Can you describe which part you think is leaking?
Posted: 20 Mar 2019 at 3:50pm |
Saw a photo of a 2 headed girl, some dentures, and the top on a faucet, so you're getting closer but not quite there yet.
Yes, its my suspicion that the upper portion of the fitting is damaged also. If you need to replace that you'll have to cut off the pex water line just below where the fitting is clamped to it and replace the fitting. Be sure to cut it off at right angles and as close as possible to the fitting so you give yourself as much slack as possible. You can use a nice sharp utility knife, just cut it square.
Then take your old fitting down to the big box hardware store and get a new push on type pex fitting so you don't need to buy an expensive clamp tool. Sharkbite is one of the commonly available brands. The fitting needs to fit 1/2 inch pex on one end and match what you have for to your flex faucet compression connection on the other end.
The sharkbite type fitting just slips over the pex pipe, super easy. The other end doesn't get any teflon tape, just screw on the flex tube fitting (very carefully by hand so as not to cross thread it). When it is as far down as you can get it by hand then give it another around have a turn with a wrench. Do not overtighen it. Then turn on your water and check for leaks, if you have a leak at that point then tighten the compression connection a bit more, but don't ham fist it.
Good luck!
Jenga Jack
Posted: 20 Mar 2019 at 3:36pm |
Photo of connector: https://postimg.cc/0zwBnB6B
Moderator: Here you go...
Jenga Jack
Posted: 20 Mar 2019 at 3:34pm |
Here's the photos, I think. And thanks for the tip! https://postimg.cc/B83MgQfj
I've tried unscrewing & screwing it on numerous times, with & w/o teflon tape. No luck. I'm now thinking that the top fitting that screws onto the connector is cracked (the fitting can't be taken off to inspect, as it's attached to the water line)
Posted: 20 Mar 2019 at 5:58am |
Its hard to tell exactly what part is leaking without pictures but it sounds like the fitting that connects from the 1/2 pex supply line to the faucet flex line. That is usually a compression fitting so teflon tape is neither needed nor will it help. Its very easy to cross thread those plastic compression fittings so I would suggest starting by unscrewing it, removing any teflon tape and other crud, then VERY carefully threading that back on being sure it is going on straight and staying straight while you're screwing it down. Don't be heavy handed, you do not want to overtighten it.
If that doesn't work then you'll probably need to replace the whole fitting, which would mean cutting the 1/2 pex water line off and using a push on type pex to compression adapter. But let's not go there quite yet...
If you want to provide a photo you can use the little tree icon above and follow the directions given there to upload your photo and link to it.
