  New Posts New Posts RSS Feed: Black tank flush connector
Topic ClosedBlack tank flush connector
mjlrpod View Drop Down
Direct Link To This Post Topic: Black tank flush connector
    Posted: 09 Sep 2018 at 9:53am
Originally posted by Old Surfer
Has anyone have had the black tank flush connection at the tank leak? Is it just 3 screws that connect the plat to the tank? What type of silicone do you use to re-seal the plat? I was thinking of adding 3 more screws to make a tighter fit? Also adding more hose to make it less rigid.
I just had this issue in august. It was leaking from the flange connected to the tank, that then the hose connects to that. I actually had the dealer fix it, as i don't really know what to use, and the wife and I agree we don't want to screw around with leaky black water issues. We want it fixed right, and guaranteed. It wasn't cheap, bout 500 bucks, but they own it if it leaks again. Just to be clear, it was leaking from the flange itself, not the hose.
BTW, I never even use the tank flush system.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
mcarter View Drop Down
Direct Link To This Post Posted: 09 Sep 2018 at 8:38am
I replaced my black tank aerator, because previous owner poked a hole in it, thinking it was clogged. Real culprit was the check valve was installed backwards. When I replaced the aerator in tank I moved the black tank flush to left side near black tank drain, no more moving flush hose around. When installing new aerator I used a commonly available exterior silicon available at most box stores.
Old Surfer View Drop Down
Direct Link To This Post Posted: 08 Sep 2018 at 10:29pm
Rick and Melanie
2008 Tundra CrewMax 4-Wheel Drive
2015 R-179
Surfer
