Page 12> |
![]() Posted: 08 Jul 2018 at 10:37am |
There is a way. Under the trailer with a bucket. With a hot water faucet open the WH should drain back through the cold low point drain. Then close all WH bypass valves and dump bucket into the FW tank. A major PITA.
Yepper, I got a around a qt out this am.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6423 |
+1 on the diagram. If all the air is not purged from the water heater, it might act as an accumulator and push some water out. However, it still won't be able to go below the level of the output since then only air would be able to be pushed out. If the pump is running dry and pulling air only, it will push air into the water heater tank but still the output of the HW tank is the lowest level to which it can drain. I don't know where that output is in relation to capacity. Perhaps a quart or two is all the "reserve" that would be available.
Happy Tripping ![]() Senior Member ![]() ![]() Joined: 27 May 2014 Online Status: Offline Posts: 473 |
Nice diagram!!
I agree, the only thing I think I saw was the WH has some pressure in it, and as I ran water longer this am, obvious I was not emptying WH. My bad.
I also have a hard time picturing how the water pump could draw from the water heater even if there is no check valve. The tank is on the output side of the pump, not the input side.
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1454 |
I guess I'd like to see a diagram of how the water heater is plumbed. To fill it from the fresh tank, you have to pump it from the tank to the WH. To get hot water out of the water heater it seems like it has to be pushed out by cold water being pumped in. I can imagine gravity playing a part here, but I'd think there must be a check valve, or something like one, to keep heated water in the tank when the pump is off, so how can the WH tank be used as a traveling reserve for fresh water? It won't amaze me if it works as you say Mike, but I'm having a hard time figuring out how to do it, short of having the water heater up on the third floor. TT
FJ Cruiser |
I disagree but agree. First off if you are traveling and not connected to any power source, the 6 gals in the water heater can be pumped out by the water pump and used as a traveling reserve. I do it all the time. I am aware that when I use the WH function I need to ensure the WH is full. That 6 gals of water will pump out. Don't heat it and don't worry about the anode. It is an available water source. Small but available.
Stephen is exactly right, but I feel compelled to expand on the anode situation. There are 3 significant components to your water heater, aside from the tank. There is the electric heating element. It has wires going to it. There is the propane heating apparatus. I've never gotten into it, so I can't describe it, but it has a propane pipe, a flue, an igniter, and some kind of burner. The functions of both the electric element and the propane burner are the same: heat the water in the tank. Then there is the anode. It screws into the tank, with no wires or pipes. It does as close to nothing as possible. This is a bit over my head in terms of scientific details, but the anode just slowly dissolves (over months or years). It dissolves to protect the hot water tank from being dissolved by electrolosis or chemical issues. It's often called a sacrificial anode because it sacrifices itself to protect the tank. Your water heater will work without it. You can replace it with a galvanized pipe plug (that will do absolutely nothing except keep water from flowing out of the hole for the anode.) It won't burn up no matter how empty the water heater might be. Turn off the water heater the instant you realize you're out of water. Electric and propane. Much better, don't turn it on unless you know the WH tank is full and you are sure you have plenty of water in your fresh tank or you're hooked up to "city water". TT
FJ Cruiser |
Page 12> |
