  New Posts New Posts RSS Feed: Fresh Water Tank
Topic ClosedFresh Water Tank
mcarter View Drop Down
Direct Link To This Post Topic: Fresh Water Tank
    Posted: 15 Jun 2018 at 3:32pm
3 years I did this issue, finally fixed when I changed the water pump. The check valve is there. Nothing obvious, never. Just didn't check. New WP fixed issue.
Direct Link To This Post Posted: 12 Jun 2018 at 6:58pm
It is likely a faulty check valve in the ShurFlo water pump. In effect, water leaks past the pump into the fresh water tank. There's supposed to be a check valve in the pump to prevent this but it can fail due to debris not cleaned out in the lines after assembly of your 172 and messing up the check valve or even have heard of the check valve being installed backwards.  Before pulling apart you could try running the pump for 5 to 10 minutes and see if anything will dislodge from the valve; some have had success with that method.  If not then you will have to disassemble and hopefully find the debris that is keeping the check valve from closing or maybe you will find it was installed backwards.  Has this been an ongoing problem?  I have to admit, our 177 is going on year 8 and I don't know if mine works correctly because I have never hooked up to municipal or other water supply, we always carry our own well water with us as we normally dry camp.
SC for Huskers View Drop Down
Direct Link To This Post Posted: 12 Jun 2018 at 4:52pm
Before leaving on a trip I put about five gal. in the fresh water tank.  After five nights camping with city water, I found water coming out of the fresh water fill spout.  Checked the level indicator and it was full.  Is there a check valve somewhere to prevent city water from filling the tank? I have a 2017 172.  Thanks in advance
Happy Traveling,
Tom
2017 172pod
2011 F150 STX
