  New Posts New Posts RSS Feed: Installing a 24" tv in a 179
Topic ClosedInstalling a 24" tv in a 179
backin15 View Drop Down
Direct Link To This Post Topic: Installing a 24" tv in a 179
    Posted: 16 Apr 2018 at 6:53pm
I just drilled new mounting holes in the existing plate. Made it as low as it could go, and so the tv is just touching the wall when in travel mode for a bit more stability. With it sitting lower, the need for a tilt feature is reduced.
2015 179
2013 Xterra Pro 4X
TheBum View Drop Down
Direct Link To This Post Posted: 16 Apr 2018 at 2:08pm
I took a couple of flat metal bars and created another articulation point in the factory mount.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
GlueGuy View Drop Down
Direct Link To This Post Posted: 16 Apr 2018 at 1:39pm
Yup. Something wrong with those links. The server portion of the URL is MIA. Cry
Direct Link To This Post Posted: 16 Apr 2018 at 1:27pm
The links are taking me to blank pages.   Can you try again?
Capt Kidd View Drop Down
Direct Link To This Post Posted: 16 Apr 2018 at 11:08am
http://joKnqC7
http://Gl9Vlkyc
http://csISKpW
What I did was to make a plate to screw into the original holes then screw the original arm into it.  The plate is the same size as the original on the arm just twice as long.
The Pirate's Pod
