  New Posts New Posts RSS Feed: Dewinterizing
Topic ClosedDewinterizing - Event Date: 22 Feb 2018
PugsNPods View Drop Down
Direct Link To This Post Calendar Event: Dewinterizing
    Posted: 26 Feb 2018 at 4:03pm
In Oregon, we never have extended below freezing times — at least in the Portland area.  I have never had a frozen water pipe at my home in over 20 years and there are exposed pipes.  I have never had a water hose freeze or crack even if they sit outside all winter.  It seems to me like winterizing is not necessary in Oregon (Portland) area but I did it anyway for the chance that December-February-January can be the iffy cold months.  Anyway — I am so grateful for all the responses and advice.  I can do this!
mcarter View Drop Down
Direct Link To This Post Posted: 24 Feb 2018 at 5:43pm
I use a heated fresh water hose.
Wepod View Drop Down
Direct Link To This Post Posted: 24 Feb 2018 at 12:33pm
My experiences are about the same.  I do have foam pipe insulation on my water intake line so I haven't ever had it freeze.
RichC View Drop Down
Direct Link To This Post Posted: 24 Feb 2018 at 9:07am
My recent experience the same as StephenH.
2017 RP171
2018 Ford Explorer
Direct Link To This Post Posted: 23 Feb 2018 at 10:25pm
Add a caveat to the above advice. If the weather is projected to be below freezing for an extended period or if it is really low (teens or single-digits), winterize.
If it is only expected to be in the low 30's or high 20's overnight AND you have heat in the 'Pod, you should be safe to not winterize, especially if the temps will be well above freezing the next day. We did some extensive traveling with temps below freezing with water in the system. The only time we had anything freeze on us was when we were traveling and it stayed below during the day while we were moving and the heat was not on. The intake line from the fresh water tank froze, but it thawed the following day with no issues.
Happy Tripping View Drop Down
Direct Link To This Post Posted: 23 Feb 2018 at 7:47pm
Find the latest frost date for your area and use that as a guide. You can dewinterize earlier, but if the weather forecast becomes 28 or 29 deg, you probably will want to re-winterize really fast.
ArenaBlanca View Drop Down
Direct Link To This Post Posted: 23 Feb 2018 at 10:08am
Hmmm.  I am in New Mexico.  In southern NM we can probably de-winterize now.  But northern NM got 6-8 inches of snow yesterday and more predicted for the weekend.  I suspect Oregon may have similar situations.  If you are on the coast, maybe now.  If in Eastern Oregon, you may need to wait a while.
Enjoy Life!!
Direct Link To This Post Posted: 22 Feb 2018 at 10:09pm
PS -- I may not have put this in the right discussion spot -- I'm still new to forums -- so let me know if this is where the question goes.
Direct Link To This Post Posted: 22 Feb 2018 at 10:08pm
Hello -- I'm wondering when people usually "dewinterize" in Oregon.  Since I can't wait to get out there, I'm looking at the first of March.  Does anyone have stories or experience around this?
Thank you!
