  New Posts New Posts RSS Feed: Hookup using RV Cord Adapter
Topic ClosedHookup using RV Cord Adapter - Event Date: 02 Jan 2018
Sierra Jim View Drop Down
Direct Link To This Post Calendar Event: Hookup using RV Cord Adapter
    Posted: 02 Jan 2018 at 8:02pm
Sounds like the solution I need. The thermostat had been operating on Fahrenheit before I used the cord adapter, I just wasn't sure how it got changed to Celsius. Probably an easy mistake to make when pushing those buttons. Thanks for your prompt response.
Sierra Jim
Direct Link To This Post Posted: 02 Jan 2018 at 7:46pm
Originally posted by StephenH
What happened is that your thermostat is set for Celsius instead of Fahrenheit. Hold the up and down arrows down and it should switch. 20C=68F and 32C=89.6F.
Yep.
Press and release the + and - buttons at the same time. That will change you back to F.
Direct Link To This Post Posted: 02 Jan 2018 at 7:24pm
Direct Link To This Post Posted: 02 Jan 2018 at 6:00pm
Was using my 2017 r-pod 179 as an extra bedroom over the holidays using a 30 AMP female to a 15 AMP RV Cord Adapter. The electric seemed to work fine, but I could not set the thermostat on my heater above 32 degrees. The temperature was actually quite comfortable with the thermostat at 20 degrees. Although I had removed the batteries for winter storage, I don't understand why I could not set the thermostat above 32 degrees?
Sierra Jim
