Page 123> |
![]() Posted: 27 Jun 2017 at 10:15pm |
Don't bother. It's been tried before to no avail. If they can't understand something as simple as FW/GW/BW systems there's little hope. However, she might have a bright future at an RV dealership. BTW I recommend the Fairview WR-RV55 pressure regulator. A lot higher flow rate than even the so called "high flow rate" regulator from Camco. It assures a full flow shower when you're at a CG with water and sewer connections. See my post at http://www.rpod-owners.com/forum_posts.asp?TID=8690&title=water-pressure-regulators-and-flow-rates |
blimey ![]() Senior Member ![]() Joined: 15 Aug 2016 Location: OHIO Online Status: Offline Posts: 102 |
ditto
Mr. Scott ![]() Groupie ![]() Joined: 08 Jun 2017 Online Status: Offline Posts: 46 |
Hah! Sorry about the font confusion. I am "Scott"!
![]() It turns out there WAS a pressure regulator on the line, so that is out as part of the equation. My wife remembers that there were some drops of water on/in the shower/toilet sink, so that must be the culprit. I'm going to check out the pump area and look at the connections for the sink in the wall. I'll see what I can see. I'll correct the FR person! Thanks so much, guys. Scott--THE Scott. |
+1, there is no path from fresh water to gray tank. I have reoccurring issue with city water going to FW tank. I spent 4 days at the ERU and on final day my fresh water tank was 1/4 full. Before that it was empty. My next step is to pull water pump and inspect.
NO. There is NO direct path for water from the city water inlet to the GREY tank. There is to the FW holding tank. Whoever "Scott" is, he is not understanding the question/problem, or he is a dumbass. |
Scott,
FR is notorious for loose plumbing fittings. Seems their assemblers are either weak or untrained. Lots of folks have had massive plumbing leaks after the first road exposure. I had shower water running all over the floor and found the P-trap not even hand tight. That's probably not your exact problem but there could be a loose connection on the supply side of the shower sink. It may be possible for water to run down from there to the shower pan and into the gray tank. Water, especially under pressure, can do strange things. If there is a loose fitting it could be spraying somewhere and following a circuitous (engineering term) path to the shower pan. As I recall there is a small access hole below the sink or you might have to remove the sink. Easy enough to do. I no longer have my Pod so I can't be exact. |
Hey, Charlie: Hah, figures. I don't think this rig has seen enough use for the pump to be malfunctioning like this. We'll see. I'm still leaning towards the high pressure/open shower sink explanation. I just wish we'd seen it! Grrrr.
Thanks. |
Not to be nit picky, but a bad check valve in the pump will fill the fresh water tank, not the gray. The symptom is an overflow of the FW tank out the overflow or city water connection. Sounds like an answer from the marketing dept. The pump check valve is inside the pump and most problems arise from some dirt or sand preventing the valve from seating. The first attack is to cycle the pump several times (with city water disconnected) to try and dislodge the dirt. If this doesn't clear it I believe the valve can be replaced but it requires disassembly of the pump. Search the internet for help on your pump model.
Hey, Podsters:
There IS a potential pathway for freshwater to the grey tank. Dig this hot off the presses from Forest River: Scott, It sounds like the check valve in your water pump may have gone bad. Typically if the check valve in the water pump goes out, the city water will end up filling the grey tank. So, folks, any tips/tricks/guidance to accessing and servicing this valve? Will I have to replace the whole pump? Thanks. Scott |
Yeah, got the BW flush figured out. I'm thinking a faucet must have been maybe a little open and I didn't hear it because of the AC. With high pressure on the line from the hose, that might have pushed a fair amount of water out, eventually filling the tank. Now, some water did flow out over the shower pan, but virtually all of it seemed to drain out underneath. The floor inside the trailer only had a small amount of water visible--like easily mopped up with a towel. Is there a secondary drain under there? Should I worry about water damage? The weather has been hot and dry, and we did a three + hour drive home in 90+ temps the day after the incident. I think it's pretty darn dried out now. What should I check?
Thanks. Scott |
Page 123> |
