  New Posts New Posts RSS Feed: Tow Vehicle Mirror Extensions?
Topic ClosedTow Vehicle Mirror Extensions? - Event Date: 11 Jun 2017
mcarter View Drop Down
Direct Link To This Post Calendar Event: Tow Vehicle Mirror Extensions?
    Posted: 12 Jun 2017 at 3:48pm
+1 to SH. Not a fan of clamp/strap on. They wobble and vibrate. Best to check options available for your make and model vehicle. Many manufactures have a towing mirror option. I replaced mine on Silverado, they extend out manually, but are power and heated. The upper half is standard side view mirror, the lower half is a convex. I can see from shoulder to shoulder on a 4 lane.
TheBum View Drop Down
Direct Link To This Post Posted: 12 Jun 2017 at 11:05am
We bought them, used them once, and then never used them again. I can lean enough to the side that I can see almost directly behind our 179.
One might be useful on the passenger side to counteract the distortion from the factory mirror on that side. It's sometimes difficult to tell when I can get back over after passing someone. However, the one we have is so jiggly when moving that I almost got sea sickness.
Direct Link To This Post Posted: 12 Jun 2017 at 9:18am
I started with towing mirror strap on, switched to ones with the ratchet clamp, and just upgraded the mirrors on our Frontier to proper towing mirrors that slide out for towing and slide back in for regular use. I like not having to deal with the strap/clamp on mirrors. I got them from 1A Auto (https://www.1aauto.com/). They weren't cheap, but they should last as long as the truck.
Codex1554 View Drop Down
Direct Link To This Post Posted: 12 Jun 2017 at 9:17am
For what it's worth, I replaced the mirrors on my Xterra with a set from a Nissan Titan.  Yes, they manually extend, but for me the convex mirror is what I use, particularly when changing lanes.  The larger mirrors combined with the extension do make the job of backing easier.
Jim
Jim McP
Beaverton OR
RPod 180 (Podamus)
Nissan Xterra
lostagain View Drop Down
Direct Link To This Post Posted: 12 Jun 2017 at 8:51am
I bought mirror extensions while I was looking for a trailer.  I tried them with our pod and found that for our Dodge Dakota 4x4 the factory mirrors work fine.  So, now my extensions are sitting in the garage collecting dust.  We have a clear view down both sides of the trailer and behind us.  As with all trailer mirrors configurations there is a cone of blindness directly behind the trailer.  As the bumper sticker on some trucks says:  If you can't see my mirrors, I can't see you.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Grandpa Hiker View Drop Down
Direct Link To This Post Posted: 12 Jun 2017 at 5:00am
I tow with a 2014 Explorer. Using the factory mirrors, I can see the sides of the Pod, but I can not see if there is a vehicle close behind me. So with mirror extensions I can get a good view of my tires & also know if someone is ridding my bumper.
Rob & Becky
2015 R-179 Pod aka Piddle Pod
Kup-Pod View Drop Down
Direct Link To This Post Posted: 11 Jun 2017 at 8:55pm
Thanks everyone, that helps.
Still getting used to the forum and maneuvering my way through all the posts.  Lots of helpful info in here!
2017 RP-178
2021 F150 5.0l
"Lead me on a level path"
GlueGuy View Drop Down
Direct Link To This Post Posted: 11 Jun 2017 at 8:53pm
Probably depends somewhat on the TV itself. When we tow with our F-150, I can see down the sides of the R-pod very well. Of course the F-150 is a lot chunkier than your average RAV4 (for example).
Direct Link To This Post Posted: 11 Jun 2017 at 8:27pm
Ditto!! I like checking the tires and the side marker lights. I think they are a plus!
john in idaho View Drop Down
Direct Link To This Post Posted: 11 Jun 2017 at 8:18pm
I like to see down the side, and peek at the tire bulge from time to time.  I don't know how one could pull back in after passing without being able to see down the side of the trailer.  Listening for honking is one way, I guess.......
