sailor323
Calendar Event: Attaching to walls Posted: 06 Jun 2017 at 7:31pm |
Screws. We've attached lot of things to the walls using screws. Use # 8 or #10 screws just long enough to penetrate the paneling completely
lostagain
Posted: 06 Jun 2017 at 8:26am |
For stuff that's not too heavy and for those plastic hooks 3M makes a double sided mounting tape that seems to work pretty well. http://www.homedepot.com/p/3M-Scotch-1-in-x-12-5-yds-Permanent-Outdoor-Double-Sided-Mounting-Tape-411-LONGDC/100153200?MERCH=REC-_-SearchPLPHorizontal1_rr-_-NA-_-100153200-_-N They also make one that has a higher capacity, but I haven't tried it.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
marwayne
Posted: 05 Jun 2017 at 12:31pm |
I think I'm the only pod owner that has added many cabinets towel bars ets, but nobody beliefs that I have not used a single wall anchor 7th season and everything is still on the wall.
Posted: 05 Jun 2017 at 7:40am |
Do advanced search -"wall anchors" - lots of good advice.
Madmojo
Posted: 04 Jun 2017 at 8:00pm |
Posted: 04 Jun 2017 at 6:11pm |
Madmojo,
If mounting into a hollow area of wall, most of us use wall anchors, select an appropriate length as to not interfere with outside skin. Take some pre-planning as a hole drilled is hard to cover-up if not needed in future. There are no studs in a Pod, if you can use an aluminum tube do so, you can find them with a stud finder. There are instances where you have to use anchors for any load bearing capability, be prudent and plan ahead.
henryv
Posted: 04 Jun 2017 at 6:04pm |
I think the best way is not to attach anything. The second best way is use velcro and avoid making holes!
Madmojo
Posted: 04 Jun 2017 at 8:29am |
I have a question for all of you that have done modifications. What is the best way to attach things to the walls. Are you using wall anchors?
