  New Posts New Posts RSS Feed: Wrecked entry step
Topic ClosedWrecked entry step
Happy Tripping View Drop Down
Direct Link To This Post Topic: Wrecked entry step
    Posted: 29 Nov 2015 at 2:55pm
Hello.
I knew it would happen, if not folded up - In spite of this, I managed to bend the bracket of our trailer's entry step on a low post. It's about 1/2 inch out of line now, still 'works' but definitely the worse for the experience.
I tried to gently push the hanging bracket back into shape with a sledge hammer, but no joy, that is thick metal.
I assume I'll have to replace the whole unit,
1. Are there special tools/steps needed to remove the bolts holding the hanging bracket onto the frame, like an impact drill?
2. Do replacement steps have the bracket attaching the step to the frame?
3. Suggestions/comments are appreciated, tho my wife has already supplied the sarcastic ones so you don't have to include those.
Direct Link To This Post Posted: 29 Nov 2015 at 6:38pm
For that type of work, a sledge isn't the tool.. You need steady leverage, a pipe wrench or large adjustable, open slightly, slide over, bend/pull steady.
john in idaho View Drop Down
Direct Link To This Post Posted: 30 Nov 2015 at 9:51am
If you can get it off, you might try taking it to a steel fabricator that makes things like truck bumpers.  Might also try a big vise if you have one.
Pod People View Drop Down
Direct Link To This Post Posted: 30 Nov 2015 at 9:22pm
there was a discussion a while back about replacing the single step with a double step.  they probably can give you good advice,
I think this is the link
http://www.rpod-owners.com/forum_posts.asp?TID=6601&title=single-step-to-double-steps
Vann
Vann & Laura 2015 RPod 179
