Page 12> |
Bonjour ![]() Newbie ![]() Joined: 18 Oct 2014 Online Status: Offline Posts: 27 |
![]() Posted: 29 Oct 2014 at 10:58pm |
It seems pretty clear that a separate voltmeter would be useful to monitor the battery. Also it would be be nice to have additional ways to power/charge various electronics. I found this multi-panel device on Amazon and wonder how well you think it would work?
How important would it be to have an on/off switch? Would this need to be connected into a fuse slot? My electrical ability hovers around zero and I would need someone to install it. Any advice would be appreciated.
Thanks |
Luv2Q ![]() Senior Member ![]() ![]() Joined: 30 Aug 2014 Location: Central TX Online Status: Offline Posts: 309 |
This looks pretty slick! I personally would like to see one more meter, though: 120v AC (though that complicates the install). Can't help you with your questions. I'd guess an on-off switch is probably not a bad idea to keep drain to a minimum when boondocking. Does it need to be fused? Well, what if you plugged something that sucked a ton of juice through the wiring (please excuse my technical terminology) and ended up overloading your wiring? I'd say a fuse is probably a good idea. What's the max amperage you might plug into either of the chargers (but especially the 12v)? That would probably give you an idea of the wire size and fuse rating you'll need.
Good luck on this .. Hope you get some good quality answers.
John & Teri
Tundra 5.7L V8 / RP 180 E2 WDH / Integrated controller (POS) replaced by Tekonsha P3 |
techntrek ![]() Admin Group - pHp ![]() ![]() Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9059 |
To monitor 120 AC I leave my Kill-A-Watt plugged in where I can see it throughout the day. Since it doesn't get used day-to-day for anything else it is a good use of it on camping trips.
Bingo! Just ordered one. Thanks, Doug ...
John & Teri
Bonjour, if you search the forums for 12 volt socket or voltmeter, you'll find lot's of different ways we have done installs.
I preferred to keep them separate. You may click the link in my sig to see my voltmeter and 12 volt socket installs. Hope that helps. fred
Podster ![]() Senior Member ![]() ![]() Joined: 16 Sep 2014 Location: San Antonio Online Status: Offline Posts: 1108 |
I use my TV to charge and maintain my low voltage gizmos. I also have a 400w power inverter for other stuff.
Question: Why do I need to monitor my AC feed? A little off-topic but Dang! I do like the mutli-panel device and wish I would have know about it when I built my Solar rechargeable 24 Amp Hour QRP field battery power supply for operating on High Frequency Radio. ![]() |
Cliff & Raelynn
From what I've been reading, the voltage in different parks can vary quite a bit, ranging from spikes down to brown outs & worse. In other words, you can't just plug into a 30-amp outlet and know you're getting 110 (or 120 or whatever it's supposed to be). Bad mojo for A/Cs, computers & Lord knows what else. I don't know how to test for whether the line is delivering 30 amps or not. Maybe that new Kill A Watt gadget will tell me. Doug?
John & Teri
Correct on the voltage - once you get down about 10%, or around 108 volts, you can start damaging equipment in the pod like the A/C compressor. Like on a hot summer day when everyone has their A/Cs on high. I've only found one campsite where this was a problem, but I'm glad I caught it. Same goes on the other end, once you get above 132. It is easier to just remember 110-bad 120-good 130-bad.
As long as the 30 amp breaker on the power pole doesn't trip, you are fine.
Ok, so if it's bad what do you do? Shut it down and go without? Or pack up and leave the campsite.
Cliff & Raelynn
Or fire up the generator.
John & Teri
Page 12> |
