Refrigerator won't start |
1963farmbox ![]() Newbie ![]() Joined: 18 Jul 2025 Online Status: Offline Posts: 2 |
![]() ![]() ![]() ![]() Posted: 19 Jul 2025 at 1:06pm |
I have a 2010 171 Rpod. Got it out for 1st time. Plugged it in to 110 for a couple of days. Everything works except the fridge. If I unplug the power cord, the Microwave will not work either. I purchased a new battery but still have same problem. Ant thoughts? Thanks, Randy
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3358 |
Need more information to make an educated guess. Do the lights work on the eyebrow board or inside when the door is open? On electric - does the chimney get warm/hot after being in this mode for 30 minutes? On propane - does the igniter click when turned on this mode, is a flame present once the igniter stops clicking? Have you checked the GFI where the fridge is plugged in to make certain you have power? You purchased a new battery but have you checked the voltage with a multi-tester or voltmeter- you should be reading 12.72v or better. Let us know what you find. Thanks
Also, check your fuses on the converter to see if there are any 'red' lights on indicating a failed fuse.
