  New Posts New Posts RSS Feed: Hot water tank
Hot water tank - Event Date: 13 Feb 2025
Jsappington0717 View Drop Down
Post Options Post Options   Quote Jsappington0717 Quote  Post ReplyReply Direct Link To This Post Calendar Event: Hot water tank
    Posted: 13 Feb 2025 at 11:17am
Where is the hot water tank on a 2021 R-Pod 193. Bought camper used and need to dewinterize it.
J. Sap
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 11:44am
Easy way to spot where it is roughly is to see where the water heater panel is on the outside. Then look inside at that area for an access panel or door or (if under the bed) under a panel. I don't have that model, so I can't say for sure, but that is where I would start.
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 1:01pm
Hopefully the previous owner did not fill it with 6 gallons of antifreeze! The bypass valves and pump should be in the same general area.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Kawasaki KLR650
GlueGuy View Drop Down
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2025 at 11:33pm
Most Rpods have the water heater access and the vents for the furnace co-located on the side of the trailer.
The large, black panel is the cover for the water heater. The two round vents are the furnace.
Pete Brayton View Drop Down
Post Options Post Options   Quote Pete Brayton Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2025 at 1:02pm
It looks like your hot water heater is located between the rear storage area and the slide out the driver's side.
 https://www.youtube.com/watch?v=-diIkDBMra0&ab_channel=BennieAust
2021 Rpod 196
2013 Ford 150 V8
