  New Posts New Posts RSS Feed: fuse box fan runs all the time
Topic Closedfuse box fan runs all the time
Lafe View Drop Down
Direct Link To This Post Topic: fuse box fan runs all the time
    Posted: 26 Aug 2021 at 9:50am
Getting ready for a trip I hooked up to shore power at home and turned the frig on. The electric plug light blinks on and off and the fuse box fan runs all the time. The frig is cooling, lights and out lets work. Is it ok if the fuse box fan runs all the time ?
Lafe View Drop Down
Direct Link To This Post Posted: 26 Aug 2021 at 10:08am
GlueGuy View Drop Down
Direct Link To This Post Posted: 26 Aug 2021 at 10:15am
You're probably hearing the cooling fan in the converter behind the fuse box. When the fan is running it generally means the battery charger is working to bring your battery/ies up to full charge. The battery/ies should get "full" in a couple hours or so, depending on their state of charge. You may want to check the battery/ies with a volt meter and also check the water level.
Lafe View Drop Down
Direct Link To This Post Posted: 26 Aug 2021 at 10:23am
Direct Link To This Post Posted: 26 Aug 2021 at 6:23pm
Proper maintenance is key to battery longevity.  Please heed GG's advice.  Invest in a voltmeter/multitestor if you don't already have one.  Got mine at HF years ago for $5 and it still works 5 years later.  Sounds like your converter is functioning properly as you hear the fan running.
Don't run your 12v battery below 60% S.O.C. or 12.2v for maximum battery life.  Keep electrolyte levels full and only use distilled water.  Keep posts and exterior battery clean by making a weak solution of baking soda and water, brush on and hose off.  Our 12v Interstates were made 12/2010 and 4/2011 and still perform very well for us boondockers.
