  New Posts New Posts RSS Feed: Oxygenics shower head
Topic ClosedOxygenics shower head
EchoGale View Drop Down
Direct Link To This Post Topic: Oxygenics shower head
    Posted: 10 Jan 2021 at 10:37am
Hi folks,
I'd read a few of you had switched out your shower heads with oxygenics spa showerhead and I ordered one. As I'm unpacking at looking at it, it seems to me that you cannot turn it off while showering. there are two setting one is a regular shower and the other is a "pulse" is this true? am I missing something?
Julie
mjlrpod View Drop Down
Direct Link To This Post Posted: 10 Jan 2021 at 11:07am
I installed an oxygenics "fury" shower head. It has a small flip switch on top to stop the water flow on it. It also has about 6 or 7 different pulse settings.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 10 Jan 2021 at 11:10am
Ah...I may not have done enough homework.  Censored
anyone else have the smaller "spa" version?  I'd like to know if there's a way to turn it off that I've missed or if it seems okay anyway.
Julie
Pod People View Drop Down
Direct Link To This Post Posted: 10 Jan 2021 at 11:24am
our oxygenics shower head came with  a push button that will make the shower head"leak"-it doesn't turn off completely so that the temp stays constant. It leaks very little and seems to work fine.
If you want to turn it off, there are aftermarket on/off attachments that can be added between the hand held unit and the hose. They are available at most big box home improvement stores. we have one on a hand shower in our home.
Vann
Vann & Laura 2015 RPod 179
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 10 Jan 2021 at 2:45pm
+1 on the after market shutoffs.  Quick, simple solution.
TT
FJ Cruiser
Direct Link To This Post Posted: 10 Jan 2021 at 3:13pm
Ohhh excellent!  Thank you.  I can see exactly how that would work.
Julie
