EchoGale ![]() Senior Member ![]() Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
![]() Posted: 10 Sep 2020 at 4:22pm |
Hi folks, My 2016 172 has this brown interior that is hard to match. In addition to the hint of gray in the color there's also the faux wood grain. I had added some trim that I had to paint when I opened the dinette cushions and painted it taupe to match some of the trim but I didn't love it. Also, the brown surface on the cabinets and the finish on the bathroom door had gotten scratched and nicked I finally found a paint color that blends (see below.) Since the cabinetry has a hard sheen but is softer inside, it works really well to dab a little paint on a scraped spot and then wipe away with a paper towel. The paint sticks to the white softer interior part but wipes off the wood grain surface. Color me elated. :) ![]() |
Julie
Unfortunately, the image is scaled so small that the print is unreadable when it is enlarged. Would you please post a larger (such as 800x600) copy of the image? Alternately, would you post the column headers and numbers and the paint base color number so that others would be able to get this also?
Haha, I'm sorry. I have had so much difficulty posting images and I used an image because I didn't know which numbers were the right ones. I will figure this out tomorrow. :)
Julie
Okay, try this:
STR #2410 PPG BASE PPGU83-340 PPG1019-7 INTRIGUE CLRNT BL CL FL KXL OZ 0 0 0 0 384th 115 52 24 49 241020314586 |
Julie
Perfect! Thank you.
