Poddy ![]() Groupie ![]() Joined: 22 Jul 2020 Online Status: Offline Posts: 47 |
![]() Posted: 26 Aug 2020 at 6:09am |
2011 RP172
2015 Toyota Tacoma Newfoundland, Canada |
Watch this video so you get an understanding of what's inside there. There should be aluminum square tubing in the walls to attach to. You will need to seal the gap up with a good adhesive caulk, screw the corners into the Al tubes, and I'd work up some way clamp/press it together while the adhesive cures. Reseal underneath too.
Tks offgrid. I'll take a look at the video.
2011 RP172
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6438 |
It probably would not hurt if you could get an anchor into the tube to provide more grip for the screws also.
