  New Posts New Posts RSS Feed: Shelf Over The Bed
Topic ClosedShelf Over The Bed
Colt View Drop Down
Direct Link To This Post Topic: Shelf Over The Bed
    Posted: 05 Jul 2020 at 5:58pm
How did you attach your shelf and what did you make it from?  There is so little in the walls, I'm not willing to just start driving screws.
I searched, but apparently didn't hold my mouth right.  I know I saw a thread on this somewhere.
John
'16 R-Pod 180
Woodmiester View Drop Down
Direct Link To This Post Posted: 06 Jul 2020 at 3:30pm
I made mine from a ready made wooden closet shelve from Lowe’s.  PERFECT for this.
I cut it to the correct length then installed a cleat to each wall for it to rest on.  For the cleats, I glued them, let it dry then installed two screws through the cleats into the Wall.  Do not use screws longer than 1 1/2 inch.
I then used a couple of finish screws to secure the shelf to the cleats.
For glue, I used liquid nails.
Been there for two years, no problems!
Swampfox
Pod People View Drop Down
Direct Link To This Post Posted: 06 Jul 2020 at 6:25pm
There are lots of ways-hollow wall fasteners, wide screws, glue, expanding screws are some ways.  Most people use the window valence as a starting point. Metal angle brackets can be used also.
I did my shelf differently.  I went front to back instead of side to side. I have a 179 which has  a wooden wardrobe that I can use as one end.I used a piece of wood on the other end. I used coarse threaded  1" screws and glued the wood to the ceiling. I cut the wood at the correct angle to match the slope of the ceiling.
the other end is attached to the wood wardrobe end
Hope this helps
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 06 Jul 2020 at 6:46pm
Did this back in 2013 and tens of thousands of miles. Still going strong.
