  New Posts New Posts RSS Feed: 179 Fridge Wires
  FAQ FAQ  Forum Search Search  Calendar Calendar  Register Register  Login Login
Topic Closed179 Fridge Wires
shortstrike View Drop Down
Direct Link To This Post Topic: 179 Fridge Wires
    Posted: 13 Aug 2019 at 12:54pm
2016 179 HRE.  During recent trip to Alaska I noticed that the slide would not go all the way out.  Looked on the side and found a bundle of wires (and one of those famous black head screws) that had apparently came out from the back and were blocking the slide.  Would like to secure the wires correctly so that the slide will go out and back without interfering with the wires.
Any chance one of you 179 owners could provide a picture of where the wires are attached per factory?
Bob & Theresa, 2016 RPOD 179
2006 Toyota Tundra 4.7 L
Prodigy P2 Brake Controller
Fastway e2 WDH
Motor7 View Drop Down
Direct Link To This Post Posted: 13 Aug 2019 at 1:57pm
Look for an empty screw hole and a wire clamp loose on the wire bundle. Just make sure you leave enough wire slack for the slide to move out and back.
2016 R-Pod 176T
