Page 12> |
Author | ||
clickscrazy ![]() Senior Member ![]() ![]() Joined: 09 Aug 2017 Location: FL Online Status: Offline Posts: 106 |
![]() Posted: 14 Aug 2017 at 7:02am |
Got the Pod home Sat. Put a dogbone 30a Female to 15a male adapter, plugged it in.
My batt reads full. Lights work. Possible Problems: 1. My AC will not turn on and the thermostat will not go above 32 degrees. But it will go down. 2. My converter started running right away. It did have a slight smell (Like I have smelled on others inverters), even though nothing was running. |
push both the + and - button on your thermostat at the same time, or learn the metric system, it is set to Celsius right now.
Your converter fan will run as it bulk charges the battery. The panel light shows the system voltage, not the battery voltage. So, since you are plugged in, the converter is showing that the system voltage is above 12.6. Has, honestly, nothing to do with your battery voltage or charge state. |
pgoelz ![]() Groupie ![]() Joined: 22 Jul 2016 Online Status: Offline Posts: 70 |
Is the thermostat set for centigrade instead of Fahrenheit?
The fan in the AC - DC converter (if that is what you mean) is thermostatically controlled and will run any time the converter is called upon to supply more than a small amount of current. It could be topping off the battery, which may show full on the four LED indicator when it is not actually all the way to 100%. If the battery is left connected for an hour or two without connecting to shore power (the trailer has a small continuous drain even with everything off), it would be normal to hear the converter fan run the next time it is connected to shore power. Unless you have a battery disconnect or physically disconnect one of the battery leads while the trailer is idle, the battery will slowly discharge to zero due to the small continuous drain. Being discharged below 50% is hard on the battery and will reduce its capacity each time it happens. Can't comment on any smell.... I have never smelled ours but we bought it used so if there is a "new" smell, that might be what you are smelling. Paul
Thank you all. Fixed the centigrade (Not sure why it went to C when we were using on F).
I was planning on plugging it in once a month and leaving it overnight. Should that be good enough to leave the battery connected or should I go ahead and keep it disconnected?
If it sits where it's easy to plug in, leave it plugged in. If you can't, add a battery cutoff switch. a month is to long. Parasitic loads will drain the battery in a week to 10 days. |
Not really. I measured about 150mA on our 171 with everything (including the antenna amp... don't forget that one) turned off. That is 3.6AH/day or 25AH/week. I think the standard trailer battery is in the vicinity of 50AH? If so, a 25AH discharge would discharge it to 50% every week. Not too bad, but not good either. Lead acid batteries degrade with every charge/discharge cycle and you would be wasting 52 cycles every year for nothing. And if you forgot it for a week, you WOULD damage it. Our two year old used 171 came with the battery connected and fully discharged. After charging and a couple equalize charges, I tested it at about 32AH on a 4A discharge, almost half what it should be. And I am frankly surprised it was that good. Much better to either leave the trailer on shore power permanently (if available) or totally disconnect the battery when not in use for more than a day or two. I installed a disconnect on the negative battery post but you can also just undo the wing nut and remove the wire(s) to disconnect the battery. Paul
Great info! With the battery disconnected, could I still use Shore power if i wanted?
Keith-N-Dar ![]() podders Helping podders - pHp ![]() ![]() Joined: 03 Apr 2011 Location: Mayville, WI Online Status: Offline Posts: 1447 |
If you lift the wires from the battery and plug your pod in then the battery wires will be hot and could potentially short out. Make sure you protect then.
Keith-N-Dar
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6431 |
Short answer: Yes. Longer answer: The converter will (if it is working properly) supply 12V power to the 'Pod when it is plugged in to shore power. If it doesn't, then you have a defective converter. A battery cut-off switch (see my mods for a picture of one) connected between the negative terminal of the battery and the negative wire of the R-Pod is the safest way to disconnect the battery and the simplest. Just turn the knob and it is done. There are no loose wires to worry about. |
Sure, no problem. But as Keith said above, while on shore power the disconnected battery lead is energized. Make sure the one you disconnect doesn't touch anything. I like to disconnect the negative lead because it is at ground potential already and will not hurt anything if it accidentally touches the trailer frame. But make sure it doesn't touch the positive battery terminal if you are shore power because that would short out the charger. Not sure if that would damage the charger or not... it is current limited and designed to be connected to a totally dead battery after all. At very least, shorting the charger output could potentially produce some healthy transients on the 12V line that might damage anything connected to 12V. I don't think it would hurt the charger itself but better to be safe than sorry. Paul
Page 12> |
